跳转到主内容
这是关于于2024年8月发布的Google Pixel 9智能手机的维修指南、拆解和故障排除信息。
How do I diagnose water damage severity?
My Pixel 9 is effectively toast after a good lengthy water submersion (cannot charge or turn on, already dried it in silica for a couple days). Went to a Google repair store, they said no current could flow into the device, saying I needed to replace the board for nearly $800... Maybe they're right, but maybe it's something like the charging part doesn't work and I'm getting fleeced.
Anyhow, I'd like to diagnose the severity of the damage myself. I have some experience in laptop repair, but not smartphone.
tl;dr - When taking apart my Pixel 9, what am I looking for in order to diagnose water damage? How can I tell if a component isn't working anymore?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @daven9433
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
Drying the phone doesn't really prevent the affects caused by corrosion.
Corrosion damage is usually obvious but component damage may not be and unfortunately there doesn't seem to be a schematic diagram available online for the phone at least none that I can find. Even the official Google Pixel repair manual only shows how to dis-assemble and re-assemble the phone.
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well.
Once you get it totally clean (or as clean as you can) and reassembled, try wireless charging the phone first and check if that works, just in case the problem is only on the charge board. If it doesn't charge at all, you may have to also replace the battery as well as it may have totally discharged beyond recovery.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Google Pixel 9 repair guide that may help.
这个答案有帮助吗?
得分 2
1条评论:
I appreciate the thorough reply, I'll do my best!
完成的
添加一条评论
添加你的答案
Dave N 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 32
总计 64
