How to fix doubleclicks?
How to repair a double clicking mouse?
I have this mouse, and on the top panel there are two black squares on the inside where the mouse cover connects to the clicky part of the buttons I suppose, these two black squares have become worn over the years, I believe this is causing the mouse to rapid fire click when I hold the buttons down. I tried fixing it with a piece of tape, but the tolerances are very fine. I looked on logitechs website for a replacement top panel, but I didn't see any. The mouse works great otherwise, and would be a shame to throw away.
Hi Fiksfak, I had a double click issue a while go and finally fixed it recently!
I thought it was the switch that was broken and repaired it, but I can’t tell what squares you’re referring to. iFixit has a repair guide, is it the box visible in the step 13 photos?
I used a pair of D2FC-F-7N. I chose the 60M for longevity, but 20M should also work, and chatter on reddit suggests many similar Omron switches also work.
My biggest learning was to make sure the switch was aligned with the board when attaching again.
Existing iFixit Guide:
Logitech G603 微动开关更换
由 Max Hajncl 完成的 分享
