跳转到主内容
加入维修社区 - 创建账户
2023 年 11 月发布的配备 M3 Pro 和 M3 Max SoC 的 16 英寸 MacBook Pro 的维修指南和拆解信息。
Battery issues after screen replacement
I performed the screen replacement from the website. The good news is the new screen seems like it's working perfectly. The bad news is that the battery seems like it is not working at all. There is an X over the battery symbol and it says it's on AC power.
I'm afraid I may have damaged the battery connector reference in step 20 of the repair. It says to life the hinge no more than 45 degrees, but I missed that. I lifted the hinge probably slightly more than 90 degrees. Is it really that delicate? I guess it's also possible the battery data cable could be the issue. I dropped it on the floor while doing the repair and it got kind of dirty. My only other thought it maybe I didn't torque down the screw enough in step 19. Hoping to get anyone's thoughts. Thanks in advance!
Update (10/30/25)
Here are my connectors. I suppose they look somewhat loose to me, but I was afraid of pushing them in further for fear of bending the ribbon cable.
Update (10/30/25)
Update after cleaning and reseating battery data cable. Looks like everything is working!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Re-seat and clean the battery data cable.
Reset SMC.
If still “X”: replace the battery data cable.
If still no battery detected: logic board connector is damaged → board-level repair required.
由完成的
@ben58240 - Can you take a few pictures of the battery connection as they are now as well as the battery data cable connections (both sides) Steps 15 ~19 and post them here so we can see what's happened.
由完成的
@danj thanks for responding, I edited my original post with some pics.
由完成的
添加一条评论
1个答案
已选择的解决方案
@ben58240 - Your second image looks like the cable end is not square in the ZIF connector. Install this gem of an App CoconutBattery let's see what it tells us so we can check the battery power connector.
这个答案有帮助吗?
得分 1
1条评论:
@danj Thank you so much for the help! I cleaned and reseated the data cable and it looks like it's working! I edited the post with the output of Coconut Battery.
由完成的
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 36
总计 317
