Wifi intel driver is down
The wifi driver in my laptop shows and error and it’s not working I tried to update it and deleted it and reinstalled it and nothing helped
Windows 11 error 43 means a device has reported a problem, often due to driver corruption, outdated drivers, or a hardware malfunction.
If you tried to update drivers via the device manager, that doesn't work very reliably.
For drivers, you might find something here https://www.catalog.update.microsoft.com... or search for "[hardware ID] drivers".
You can find the hardware ID in the Device manager.
If you find a new one delete the old one b4 you try to install the new one.
If that doesn't work, the next step would be to replace the WiFi daughter board.
这个答案有帮助吗?
Ah yes, the classic ‘I deleted it, reinstalled it, cursed at my laptop, and it still won’t work’ scenario.
Here’s what I’ve learned the hard way: Windows Update is usually wrong about Wi-Fi drivers. Go straight to the manufacturer’s website and get the official driver. Uninstall, reboot, install.
Also, sometimes the Wi-Fi card just wants a nap — check Power Management settings in Device Manager. After I did that, mine came back to life like nothing happened.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 172
@laithlakmoush
what error message did you get in device manager?
what os version is your computer running? win 11?
由 Augustine 完成的
@salmonjapan
Error message: Windows has stopped this device because it has reported problems (code 43)
Win 11 64-bit
由 Laith Lakmoush 完成的
