跳转到主内容
Introduced in 2003, the Dell Inspiron 5100 is identified by the model number PP07L.
The part of the laptop where the charger is broken?
The laptop charter/where the charger goes got all messed up. Despite this, the laptop still works. (Can't turn on obviously, but it would if it could be charged.) Should I have the laptop repaired? Or should I have the hard drive removed? IF I can get the laptop repaired how should I go about doing this in the most cost effective way?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Rachel, I suppose you are talking about the DC jack. It is soldered to your motherboard. Here is the service manual. It looks like it is a straight forward job to get to the motherboard. Once you have full access to your motherboard, take a look at the connector, it might be of or the solder connection might be loose. You can either resolder it, or if it looks to bad, replace it. You can get a replacement from here Total cost should not exceed $10. Sounds like a pretty cost effective task. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
2条评论:
neither link works
完成的
rickkop that is because this answer is 6 years old ;-). You can get the service manual from from here Some 2 minutes on Google finmds the part at places like this
完成的
添加一条评论
Fixing this issue involves re-soldering the power jack on mother board and I`m afraid it wont be possible with regular soldering iron. I would suggest to take it to some hardware shop and get it fixed because a wrong attempt can may harm your laptop more.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rachel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 1,698
