跳转到主内容
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
797 个问题 查看全部
Why wont my kindle fire allow me to display pictures online?
Since getting my kindle fire I have viewed web pages regularly. I have never had any problems until now. My kindle fire allows me to pull the web page up and read the text but if there is a pictures the box stays white and the picture wont pull up. Its really aggrivating could someone please help???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
1条评论
I have the exact same problem with a very sudden onset! Although it's 2020 now, I have the fire hd 8. The show image option seems non existant..i can't locate it ANYWHERE! I did the factory reset and apparently,enough my kindle has a regular backup schedule and showed a recent backup...nothing was actually backed up. So...I lost a lot of content AND it did not bring back my ability to load images. The odd thing is,this is a problem usually occurring on shopping sites like hsn,acc etc the scrolling ads show up but merchandise images do not. I get a white square and place holder right after the images flash on the screen. I attempted to use a different browser, got firefox, it works but so slowly you'd think I'm on a landline dial up! I have the highest upload speeds available in my area and we use xbox with no speed issues,watch movies with no issues but loading images on the kindle?...nope! Can anyone help please?? Thanks!
完成的
添加一条评论
5个答案
最有帮助的答案
terri, check the settings on your browser. Open up the browser, hit the menu button at the bottom of the screen, hit the Settings button, and try to enable your plug-ins and see if you are in mobile or desktop view. See if that makes a difference.
这个答案有帮助吗?
得分 3
2条评论:
Ok that didn't work but I went to settings and scrolled allthe way down to default settings and hits ok and BAAAM that totally loaded all the pics thanks for ur help
完成的
Good job, happy browsing:)
完成的
添加一条评论
bold textGo your upper left hand corner when you are in SILK. Hit the three bars, the web page will slide to the right and the term web content will appear at the top. Select settings then select advanced. Then check the box to show images. And you're done.
这个答案有帮助吗?
得分 1
添加一条评论
Hey - I also had the same problem - no pictures showing up on a web page. Did the reset and like oldturkey03 says: BAAAM! Images now showing up.
Thanks -
这个答案有帮助吗?
得分 0
添加一条评论
Thanks you guys!!! I was having the same problem and busy surfing the web looking for a solution!!!!!!
这个答案有帮助吗?
得分 0
添加一条评论
My Fire Tablet won't open window only withJPEG
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
terri 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 27
过去 30 天: 75
总计 31,097
