跳转到主内容
加入维修社区 - 创建账户
Logitech Signature M650 无线鼠标的维修指南、拆解信息和故障排除。可通过零件号 (P/N) 910-006250、910-006251 和 910-006252 进行识别。
Logitech Signature M650 left click not working
Why is the left click on my Logitech Signature M650 mouse not working properly? I have to press it harder than usual or force click for it to register. What could be causing this, and how can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Had same issue, disassembled and got some WD40 into the switch button works for me.
由完成的
添加一条评论
3个答案
最有帮助的答案
The switch failed. You can find the part on Amazon or AliEx. Search for phrases like:
Silent Mouse Button Switch 6*6*7.3MM Square Microswitch Two Pin
The switch is 7.3mm tall, and 6mm (or 6.2mm) square. You will need a solder sucker or wick, and to remove the board from the shell (4 screws and carefully pry out the battery contacts). The switch is held on by its own 2 pins and is easy to remove.
Update (11/16/25)
Getting in to the mouse is pretty easy. Start with these two screws inside the battery door. Then gently separate the mouse from the back. There is a clip near the front so you have to kind of slide the bottom forward to release it.
Remove the main cable
Remove 4 screws for the PCB & scroll wheel (scroll wheel comes off separately)
Remove the battery terminals by gently pulling up the whole PCB. Don't bend or stress the battery wires.
Use a solder-sucker to remove and then resolder with new switches for the left and right mouse button. .
这个答案有帮助吗?
得分 3
1条评论:
Instead of replacement with non-stock ones, a semi-permanent fix may be to simply exchange the right and left switches (assuming that the left one has worn out way quicker).
由完成的
添加一条评论
Yup, same problem. Disassembled it. Tried to directly press the button underneath slightly, which is just right for my use - doesn't register. Have to press it harder. The disassembly process is just like M550 (on Youtube), but be careful of the extra twisted wire for LED on the top shell on the M650.
So far, finding the switch for the 'SW1' has been unfruitful. Will update if I find anything.
这个答案有帮助吗?
得分 1
1条评论:
There are many on Amazon or AliEx. Search for phrases like:
由完成的
添加一条评论
Thanks for providing the switch specifications! Successfully replaced both switches on my Logitech M650. The disassembly is straightforward and easy. I boght the switches from china, via Shoppee in the Philippines. The left button now registers light clicks perfectly instead of needing heavy force to actuate.
这个答案有帮助吗?
得分 1
1条评论:
That's great news! thanks for sharing.
由完成的
添加一条评论
添加你的答案
Horenus Dessalegn 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 66
过去 30 天: 349
总计 3,023
