跳转到主内容
加入维修社区 - 创建账户
Water Pump Constantly running
I have a problem with my delonghi coffee machine. the water pump is constantly running with the water going to overflow tray. As soon as I plug the machine to power socket the water pump starts running (even if machine is turned off). What can be the solution please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@victor17222 Which model ist it? ETAM ???? I think its an issue with the motherboard, perhaps it must be replaced.
这个答案有帮助吗?
得分 1
2条评论:
It is Etam cappuccino Eletta, so pcb board then?
完成的
@victor17222 Look at the type plate: it should look something like this ETAM 29.666 or ETAM 36.366. There are essentially two different circuit boards, but you need to know the exact part number, printed on a sticker. Both cost around €65. Or try to have it repaired; there is a special workshop.
完成的
添加一条评论
添加你的答案
victor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 189
