跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
PS3 Not turning on
When playing with my PS3, it just powered down, and then it flashed a flashing red light, then pressing the on button, it went green, then back to a flashing red light with nothing on the screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
It could be 2 things!
1: PS3 is overheated and so you need to remove the dust and replace the thermalpaste.
Always try that first!
2: APU issues! You can try the reflow first and see if that works! Most Of the time this fix is temporary… a reball will solve it, but is very difficult to do and you need special equipment.
Guide regarding the reflow: 修复死亡黄灯
Please let us know how it goes!
这个答案有帮助吗?
得分 2
2条评论:
A reball won't fix it, the issue is the connection between the die and the interposer. It needs to be replaced with a 65 or 40nm GPU for a true permanent fix. I recommend watching RIP Felix on YouTube if you want to explore this more.
完成的
It's a possibility that there are colt solder joints beneath the GPU. Reballing will fix the colt solder joints. If it's between the die and the interposer then indeed a reball won't fix it. Do you have a link for where Nihal can buy the GPU? Thanks in advance!
完成的
添加一条评论
添加你的答案
Nihal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 78
