跳转到主内容
加入维修社区 - 创建账户
ThinkPad T470p 是 Lenovo 推出的一款实用型笔记本电脑,凭借其舒适的键盘、出色的续航能力和卓越的耐用性,非常适合商务办公。本页面将提供 T470p 所需的维修和故障排除信息。
How to change SSD
Hello. Does anyone here know whether it's possible to change the SSD in a Lenovo ThinkPad T470p (upgrade from 256 GB to 1 TB)? I only saw guides for the T470 and T470s.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @anneschu
Here's the hardware maintenance manual for the laptop.
Go to the bottom of p.66 (72 of 106 pdf) in the manual, to view the procedure to replace the SATA storage drive.
The M.2 SSD removal procedure follows on p.68 (74 of 106 pdf)
这个答案有帮助吗?
得分 2
1条评论:
Thank you! Will try and follow this.
由完成的 分享
添加一条评论
Yes, you can upgrade the SSD in a Lenovo ThinkPad T470p from 256 GB to 1 TB. The T470p supports an M.2 NVMe PCIe SSD and a 2.5-inch SATA drive, so you can replace the existing SSD or add a second one, depending on your current configuration. To upgrade, power off the laptop, remove the bottom cover, disconnect the battery, and replace the existing SSD with your new one. After installation, reassemble the laptop and reinstall Windows or clone your old drive. Always back up your data before upgrading and check the BIOS for proper SSD detection afterward.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anne Schumacher 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 58
总计 640
