跳转到主内容
加入维修社区 - 创建账户
Kobo Nia 于 2020 年 7 月 21 日发布。它拥有一块 6 英寸的电子墨水屏(E-Ink),分辨率为 1024 x 758 像素,像素密度为 212 ppi。
Rubber Power button cover replacement
My N3060 NIA has a rubber membrane covering the power button. The membrane on my KOBO is so worn out that I have removed it. I can still turn the unit on using a tooth pic or match stick. Can I get a replacement rubber membrane/power button cover?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have this problem too, but I can no longer turn it on using a tooth pick. Can someone please post an image of what the back of the motherboard is supposed to look like?
Thanks
由完成的
添加一条评论
1个答案
I have the same problem did you find a solution ?
这个答案有帮助吗?
得分 0
1条评论:
Still no solution except that i had the rubber cover removed and I turn it on with a wooden match stick You can see the on/off button when the rubber membrane is removed.
由完成的
添加一条评论
添加你的答案
Greg in Aurora Canada 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 79
总计 472
