跳转到主内容
Announced on 15 October 2023, identified by model number SM-A055M
How to change my down board
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@eviplli are you referring to your charging board? If not, you will need to clarify what down board you are referring too.
完成的
添加一条评论
1个答案
最有帮助的答案
@eviplli just in case you are referring to the charging board :-)
Since iFixit does not yet have a specific guide for this, use something like this video to work on your phone. You do not need to remove the main board. Make sure that your issues are coming from the charging board. The A series has issues with the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Evipl Li 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 34
