跳转到主内容
加入维修社区 - 创建账户
Xiaomi Mi 11 Lite 5G NE 是小米于 2021 年 9 月发布的一款中端智能手机。它配备 6.55 英寸 AMOLED 显示屏、6400 万像素主摄像头、侧边指纹传感器和 4250 mAh 电池,搭载骁龙 778G 处理器。
How to reconnect screen cable
My xiaomi 11 lite 5g ne sometimes the screen went black and showed green vertical lines. When I pressed near the front camera, the screen worked again normally with no issues in touch or colors.
But after the last time my phone fell, the screen turned off completely. I tried pressing the same spot (this time with more force), and the screen worked again for about 2 minutes, then went black permanently. Now it doesn’t respond no matter how much I press.
Could this mean the display cable got disconnected? If yes, how can I fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This sounds like a problem with the delicate connections between the glass that the display circuits are printed on and the flex cable leading to the motherboard. Unfortunately, those connections are not considered repairable (at least, not without equipment costing several thousand dollars), so the only real solution is to replace the screen.
This guide shows how to replace the screen+frame assembly on your phone.
Manuales / Xiaomi Mi 11 Lite 5G / Fullscreen - Nadie Me Llama Gallina
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
unknown account 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 38
总计 376
