跳转到主内容
加入维修社区 - 创建账户
Kenmore 是 Sears 常见的家电品牌,但 Sears 本身并不生产任何家电。相反,他们会将生产任务外包给其他制造商。Kenmore 冰箱由多家不同的制造商代工,包括 LG、Electrolux、GE 和 Whirlpool。
Door bottom support broken
Refrigerator door is misaligned. Too low, scrapes the bottom of inside of frig as you try to close. Tried a taller leveling screw but bottom of frig door just collapses and door will not get back to original location. Is the bottom of the door that supports the leveling screw replaceable or fixable. Thx
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @bdwest23242
What is the model number of the refrigerator?
由完成的
253.67879509
由完成的
添加一条评论
1个答案
Hi @bdwest23242
If the lower door scrapes the inside of the compartment, it may be a loose lower hinge bracket, worn hinge pin or spacer.
Here's a video that shows how to replace the hinge pin that may help.
It shows how to gain access so that you can check if the bracket (bent/loose?), the hinge pin (worn?) and spacer are all OK or not.
If replacements are required, the part numbers are as follows. Search online for the part number only to find suppliers that suit you best.
lower hinge pin = 240516502
spacer = 240311303
lower hinge bracket = 240314011
Note: The refrigerator is a Frigidaire model, made for Kenmore as it is made entirely from Frigidaire parts. That's why parts results show Frigidaire name. Kenmore doesn't make appliances, they rebadge/made to order other makes of appliances e.g. LG, Frigidaire, Whirlpool etc
Connects the refrigerator door to the lower hinge, allowing it to pivot.图片
产品
Electrolux Refrigerator Lower Hinge Pin - 240516502
$53.99
Supports the refrigerator door at the lower hinge point.图片
产品
Electrolux Bracket-Lower Hinge - 240314011
$65.99
Nylon washer for refrigerator hinge, sold individually.图片
产品
240311303 - Frigidaire Refrigerator Hinge Nylon Washer
$18.99
这个答案有帮助吗?
得分 0
2条评论:
Unfortunately lower bracket all good. So is pin and spacer. It’s the door itself that has an issue. Caved in and can no longer support the pin. Thx for the reply. I’m assuming I would have to change door. Correct ?
由完成的
@bdwest23242
Looks like it will have to be as they're a sealed unit i.e. filled with foam insulation
According to this parts supplier there are 3 doors compatible with the model
Part # 241623407, 240438617 & 240438619 click on Door parts diagram, expand the diagram to see part #15 in the diagram.
由完成的
添加一条评论
添加你的答案
Bdwest 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 12
总计 200
