跳转到主内容
The first Legacy was available at Japanese dealerships on February 1, 1989, with worldwide distribution starting in 1990.
14 个问题 查看全部
Seized Left Rear Wheel
my L/R wheel is seized,is it the rear hub unit bearing?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
7条评论
What is your definition of "seized"? what does it do and what does it not do? Did this just start? What type of transmission does it have?
完成的
wheel will not engage forward or reverse,just happened,auto transmittion
完成的
is it FWD or AWD?
完成的
Its All Wheel Drive
完成的
Same thing, check the brakes, see if you can release the brakes and if your wheel will turn. Possible seized bearing or seized rear differential :(
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
Donna, if it is a FWD model, it is possible that your hub has seized up. Of course, the only way to really determine this is to, jack up the car, remove the wheel, and remove the rear brake. Possibly that your break is causing this too. Check to make sure that the brake shoes from the parking brake are properly releasing, and the the brake caliper is not seized.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Donna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,256
