跳转到主内容
2016年版Retina MacBook的更新版本。型号A1534,EMC 3099。现在采用更快的Kaby Lake处理器,最高可达1.4 GHz Core i7,支持Turbo Boost加速至3.6 GHz,SSD速度提升高达50%,并支持高达两倍的内存。
MacBook is taking power but is not turning on
I bought this MacBook knowing that it didn't turn on. Now I'm under the hood, the light next to the battery disconnect is lighting up, but still no boot. When I plug it into power without the battery connected, the light comes on, but still nothing. The area around the keyboard warms up like my working MacBook Pro when charging. The MacBook is taking power but is not turning on. I've checked the charge port (no physical damage), all the ribbon cables (also no damage), and still nothing. Could it be the actual power button? Idk what to check next.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
To diagnose you'll need a USB-C power meter which you put inline with your charger so you can monitor the voltage level. Here you should see a voltage change as the charger is handshaking with the system to determine the required voltage. If that is not happening the power logic needs repair.
As far as the Power Button is not easy to get to at you need to short across two of the contacts of the keyboard cable connector basically emulating what the switch does. Check the power first. You'll want to get the schematics and board view drawings to locate the pins you need to short out.
这个答案有帮助吗?
得分 1
添加一条评论
@bve45 we need to actually see your logic board. To check your power button, apply a jumper (use something like a screwdriver) across the two contacts shown, to turn your laptop on. On the keyboard connector itself, it will be pin 22 to ground. Now, you should still check the power etc. if it does not come on.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
2条评论:
I tried the debug "buttons" and that did nothing, both with the battery connected and not
完成的
@bve45 that means your board is not turning on. now it's your turn to check thigs out further. Contact me by email if you need the boardview and schematic
完成的
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 80
