跳转到主内容
加入维修社区 - 创建账户
适用于 2020 年 4 月发布及推出的第二代 iPhone SE 的维修和拆解信息。
Battery dies super quick
It dies so quickly
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Could you elaborate more? As far as I can tell you just need to replace the battery
这个答案有帮助吗?
得分 1
3条评论:
Oh no the battery compadity is literally 79 %
由完成的 分享
@thecat847 Yeah that is way too low. At 85 you should replace it
由完成的 分享
It works but I do have a toolbox to take out screws but no way to soften the glue and no replacement battery
由完成的 分享
添加一条评论
Go into your Settings under the battery heading will be the battery health. It's a percentage from 0-100 showing what the current capacity of the battery is vs. how much it should be able to hold. If it's less than about 85%, Apple says it should be replaced.
Over time batteries lose the ability to hold a full charge, so even though it says it's charged to 100%, it may only be holding 2/3rds as much charge as it should, meaning it's going to die in a much shorter time than it used to.
The solution here is to replace the battery. iFixit has a guide showing you step by step how to do that yourself. Note that unless you buy a genuine Apple battery (and have iOS 18 or later), you'll lose the ability to view the battery health information and get a pop-up warning for a week or so that the phone cannot determine if the battery is a genuine apple part. Other than those issues, an aftermarket battery will charge and work normally.
iPhone SE 2020 Battery Replacement - iFixit Repair Guide
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
The cat15 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 207
