跳转到主内容
加入维修社区 - 创建账户
高尔夫五代(Golf Mk5)于 2003 年秋季在欧洲推出,并于 2004 年初进入英国市场。在北美,大众在 2006 年引进该车型时,重新启用了 Rabbit 这一名称。
Climatronic is not working
How to repair clima compressor
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Ac repairs are not DIY friendly due to most diyers unfamiliar with vehicle refrigeration repairs encompassing; tools and equipment needed for correct, safe, removal of refrigerant, determiing what parts need replacing, flushing the system of oil and contaminants if sealer was ever used, replacing oil, replacing old valve cores in both service valves, using new seals everywhere to ensure against leaks from a pressurized system whether operating or not, evacuating a repaired system, final leak test in a vacuum before refilling with new refrigerant. Diyers familiar with ac repairs will use refrigeration gauges to assess system refrigeration capacity in determining whether a leak or compressor damage occurred. As a rule, diyers are not equipped or skilled in repairing ac compressors other than replacing a blown clutch coil along wth new idler pulley and clutch plate. Compressors are replaced in its entirety.
If you are fortunate and a leak hasn't occurred requiring all the aforementioned items to make repairs, this may be as simple as a worn out compressor control valve operated electronically to govern compressor operation; https://www.youtube.com/watch?v=94dRjWG9...
这个答案有帮助吗?
得分 0
1条评论:
gas system is ok.
compressor is problem. i will replace control valve, and hope that it will work.
thank you wery much.
由完成的
添加一条评论
添加你的答案
orban orban 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 192
