跳转到主内容
加入维修社区 - 创建账户
HTC Desire 310 - no command
Hello, I am trying to see if I can fix my HTC Desire 310 in any way, I probably have some images on it that might be worth saving, but its giving me a hard time.
  1. I cant even power on the phone with the power button. It seems like the button might not be working at all.
  2. When I connect the phone with USB cable, it shows the battery charging image, and then the percentage at what level the battery is. So that seems to be working.
  3. Then I plugged the phone in the USB cable so that it powers on, and I held the volume up button, and it gets to the android screen and it says "No command".
  4. Then I tried the same, but holding the volume down button this time. It gets to the factory mode, where I only have 4 options. Item test, cleat test report, version, and shut down. I have tried playing around the item test, I tried the touch panel, and when it opens the test, nothing happens. No matter where I press on the screen, or even if I hold and drag across the scree, it doesnt seem to do anything, the test fails.
So that is pretty much where I am at with the phone right now. It seems it doesnt get far enough for the computer to detect it, however it makes the sound when I connect it to the USB cable.
Any ideas what would be the best steps to take to get to the end of this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Have you tried using wired computer mouse? Most Android phones will automatically detect a mouse that's plugged into the USB-C port and allow you to use that to mouse around the screen and click. Since most existing mice use a USB-A plug, pick up a cheap USB-A-to-USB-C adapter to let you plug it in.
这个答案有帮助吗?
得分 1
3条评论:
Lets say it would work, where would that help me anyways? :)
完成的
The cable in question is a OTG or on the go cable. Connect your mouse and unlock the phone go to settings and remove any screen lock. Then go to display settings and set the screen auto off for 20 minutes. Go down to about and keep tapping build number until ‘you are now a developer’ pops up. Go back then into the new developer menu and enable ‘usb debugging’ now when you connect your pc it shouldn’t ask for permission to connect to the phone.
完成的
Sorry, I dont think you are in the correct thread, please red the OP for my problem if you maybe know the solution :)
完成的
添加一条评论
Have you downloaded the htc repair software? If not, have a Google and try that.
这个答案有帮助吗?
得分 0
1条评论:
If you mean the EaseUS ones, yes I have tried. Pretty much none of those work at the stage my phone is in. They all require unlocked screen and so on.
完成的
添加一条评论
添加你的答案
cipanetheI 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 191
