跳转到主内容
加入维修社区 - 创建账户
由市售 DIY 零件组装而成的台式电脑,而非来自大型制造商的预装机。这些电脑也可以由系统集成商使用市售零件来组装。
bluescreen of memory management
my pc gets memory management error out of nowhere and reboots several times when i open many apps or gets booted bhen playing games or doing any of the work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
  1. Check memory seating inside PC , in the slots
  2. Run ram check
  3. Test with diffrent good known ram & re-run ram check (if bad > )
  4. clean slot or cpu pins
  5. If it works with new ram , clean the old ram golden pins with eraser &/or contact cleaner + a brush
  6. Re-test.
  7. Update bios , set manually ram timings & voltage to ram maker specs ,
  8. Check motherboard compatibility with problematic ram on mb maker home-page. (if it's not in the QVL list it may not work properly so test your ram on diffrent system.)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Yasir Arfat 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 22
总计 182
