The bottom speaker not working - sounds terrible and staticy
And i don’t know if it’s cause the bottom speaker don’t work but it’s sounds terrible and static
@pupusa first do a visual check of your speaker. Check the speaker cone for any rips or tears. Yes, you can gently push the speaker cone inward and if you feel a scraping you may have a damaged speaker. The most reliable test would be to check for continuity and resistance of your speaker. Here is a good guide on how to check speakers and the wiring 如何测试扬声器和电线
If your speaker checks out okay, you need to check the amplifier circuitry of your PartyBox. For that use the SM that you can find under the Documents Tab on this JBL PartyBox 300 page. Pay particular attention to the capacitors in this circuit.
If you are unsure about those components, post some good pictures of the circuit board with your question. that way we can see what you and hopefully help you out further. 在已经存在的问题里加入图片
这个答案有帮助吗?
You have to check out the resistance of the speaker, try to manual push the speaker part to check is it stuck in the magnet. If everything's ok with the speaker, check the speaker amplifier IC.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 47
