跳转到主内容
Should I remove SSD in my situation?
Hi there.
I want replace my broken screen and first of all I should remove the display. So I stopped at this step: MacBook Air 11" Mid 2011 Display Assembly Replacement cause I have broken thread of screw. Its bad I know but I do not want replace SSD. So my question: Can I continue this guide without remove of SSD?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
It appears to me that you can continue with the guide without removing the card. Just be sure to observe ESD protocols when working on your machine, read through this before working on your machine: Electrostatic discharge (ESD) control
这个答案有帮助吗?
得分 2
1条评论:
Thanks a lot. But I found problem with this: in next steps I should remove cooler but I can't do that without remove SSD, because screw hidden under SSD :)
完成的
添加一条评论
添加你的答案
Maxim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 974
