跳转到主内容
加入维修社区 - 创建账户
How to replace the keyboard
Now I will show you how to replace the keyboard of a Dell Inspiron laptop.
You have to prepare some equipment including a flathead screwdriver and a new keyboard.
Remember to remove all the peripherals like the AC adapter and battery from the laptop. Don't use a razor blade because it might leave some scratches on your laptop.
There are 8 steps in total:
  • First, slide two battery-release latches into the unlocked position.
  • Next, remove the battery from the battery base.
  • Then, turn over the laptop and open it.
  • After that, use a small flathead screwdriver to pry away 5 keyboard latches.
  • Next, you should carefully lift the keyboard.
  • Then, disconnect the keyboard cable.
  • After that, remove the old keyboard.
  • Finally, reverse the above steps to install the new keyboard.
I have just told you the steps to change the keyboard. If you have any questions, don't hesitate to contact us.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I need some images and instructions on each image
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
Hi @jaygizo
Here's the ifixit AST Ascentia 520i 拆解 guide that may help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anh Tuan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 36
总计 209
