跳转到主内容
加入维修社区 - 创建账户
iPhone 12 mini 于 2020 年 10 月 13 日发布,是苹果 iPhone 12 的较小版本。它配备 5.4 英寸 OLED 显示屏、A14 Bionic 处理器以及后置双摄像头。
which speaker needs replacement
I use my (corded) ear phones or turn on speaker to hear a phone conversation. Which speaker needs replacing?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you can't hear phone conversations unless those methods are employed, you need to replace the "Top speaker" or "Receiver speaker" (it's called either). It's part of the sensor assembly on the back of the display. Some of those sensors are tied to Face ID function so you'll either need to solder a new speaker into the flex cable, or use Apple approved methods of replacing to retain Face ID
Replace an earpiece speaker or sensor assembly compatible with the iPhone 12 mini models A2176, A2398, A2399, A2400.图片
产品
iPhone 12 mini Earpiece Speaker and Sensor Assembly
$23.99
这个答案有帮助吗?
得分 2
3条评论:
I am replacing the battery and screen as a first timer. Are you saying I can replace without soldering if im willing to let go of face recognition? I will absolutely never use that tech.
由完成的 分享
Also there is no mention of soldering in the directions to replace "sensor assembly"
由完成的 分享
@maurak13 If you replace the whole assembly then no, but you will lose Face ID. Otherwise you can transplant the speaker from another flex cable, but those are soldered into the sensor assembly.
In comparison Apple would probably have you replace the whole display assembly.
由完成的 分享
添加一条评论
@maurak13 As an example, here is a guide showing how to replace the earpiece speaker without losing Face ID. This is for an iPhone X, but the last step of removing the speaker will be similar to what it would be on your phone.
iPhone X Earpiece Speaker Replacement Without Losing Face ID - iFixit Repair Guide
Just follow the iPhone 12 Mini earpiece speaker assembly replacement guide up to Step 27, then switch over to Step 29 of the iPhone X guide. The spots you need to unsolder will be in a slightly different place, but the procedure is basically the same.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
maurak13 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 38
总计 514
