跳转到主内容
加入维修社区 - 创建账户
Acer Extensa 系列办公及商务笔记本电脑的维修指南与支持。
wifi switch not working
my wifi front switch not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The Wi-Fi switch on Acer Extensa laptops is only a hardware toggle. If it doesn’t work, check these points:
1. BIOS setting – Enter BIOS (F2 on boot) and confirm wireless is enabled.
2. Function key – Some models need Fn + F3 (or the key with an antenna icon) in addition to the physical switch.
3. Drivers – In Windows, check Device Manager → Network adapters. If the wireless card is disabled, right-click → Enable. If missing, reinstall the driver from Acer’s support site.
4. Power management – In Device Manager, open the Wi-Fi card properties → Power Management → uncheck “Allow the computer to turn off this device.”
5. Switch failure – If the physical slider is broken, you can bypass it in software by forcing the Wi-Fi card enabled in Device Manager or BIOS. Hardware repair would require replacing or bridging the switch contacts.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AYINDE SAMUEL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 166
