跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Connector different from iPhone 8X
New iPhone8 battery from iFixIt will not connect - the connector on battery and in phone seem to be the same, but will not "snap" into place. Might I need an iPhone8X battery? Any other suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
There is no iPhone 8x or do you mean the battery or your phone is different than what the battery was intended?
Look at this image which is your phone?
And then look at the iFixit battery it should tell you which phone it's intended for.
If it's correct, look at the battery connector both the battery and the phone are any of the contacts damaged or the plastic pushed in blocking the connection.
这个答案有帮助吗?
得分 0
添加一条评论
@pleasedont46099 iPhone 8 and iPhone 8 Plus share the same battery connector. Physically, the 8Plus is a larger battery and will not fit a regular iPhone 8. Double check your phone to figure put what model you have. You can use this site for that Of course, you can also try that by the battery connector
If in doubt, take some well focused pictures of the battery connector and your replacement battery (if you still have the old battery, a picture of that as well) and post those with your Question. That way we can see what you see and hopefully find out what's going on with this. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
PleaseDontCreateAnAccount 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 89
