跳转到主内容
加入维修社区 - 创建账户
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
PS5 Fuse F7002 broken
Hi,
I’m completely new to this topic and I want to repair my PS5.
The problem: The PlayStation beeps briefly when I press the power button, and sometimes the blue light flashes for a moment. But it doesn’t start.
Current status:
I bought the PS5 as “faulty.” The fan connector is torn off (see attachment), but I don’t think that’s causing the problem (or is it?).
The fuse at F7002 has no continuity, and some of the capacitors on the backside show continuity (maybe that’s the actual problem—if so, what should I do?).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Well, the fuse need to be replaced for sure to get it working again.
The fan connector does not creating this fault, but would replace the connector for a new one. Just to make it work.
After this, I would run some tests on the motherboard and see if the capacitor are fine as well.
Please let me know if you have any questions!
这个答案有帮助吗?
得分 1
2条评论:
Tranks, but the caps Need to be replaced too? And is the Same Fuse in the ps4 (for replacement)
完成的
Hi!
I would buy specific for the PS5! Just in case.
Link: https://www.aliexpress.us/item/325680760...
Yes, you can replace them too and see if it works afterward!
完成的
添加一条评论
添加你的答案
Gabriel Schneider 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 60
总计 343
