跳转到主内容
加入维修社区 - 创建账户
1975-2011 (图片所示为 2008 款 Grand Marquis)
Brake lights keep going off
Wiring under steering wheel seems to be shorted or disconnected which causes the brake light to stop working
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Mercury made their Grand Marquis from 1975 to 2011, so that's a lot of changes over the years. What year is yours?
由完成的 分享
I believe that is the problem. It looks as if someone just spliced some wires together under there and wrapped them in electrical tape. My car is an 06.
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Without knowing the year I can't look up specific information but it's very likely there's a switch on the brake pedal itself that activates the brake lights. Look for it on either the pedal arm or a bracket right next to it. Try manually pressing the switch button and see if the brake lights work when you do. If not you may have to replace the switch. You should be able to test it out by unplugging the wires and shorting them together; the brakes with either come on or go off when you do; that would confirm the switch is dead.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shade Tree 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 40
总计 453
