How to check transmission fluid
How to check transmission fluid on 2002 530i bmw
dan, BMW first did away with transmission dip sticks, due to the usage of "lifetime oil" there are ways to check it, but it is not easy. "The transmission "check" is the fill plug accessed from under the car, there is a procedure for it being at a certain temp, car running, etc.
-Car must be level
-Drive vehicle to warm up ATF to operating temp. Fluid must be at 85-120F temp. Connect BMW diagnostic scan tool DISplus, MoDiC, GT1 or equiv to determine fluid temp.
-With engine running, switch on A/C to increase idle speed, apply parking brake
-With foot on brake firmly move gear shift selector through all gears, pausing briefly in each gear.
-Raise vehicle
-With engine running and gear in PARK, remove filler plug. If small stream runs out level is correct. If none trickles out level is low.
Check this this link to see how to change it. You will find more info about the BMW on here. Here is the part of the Bentley manual that might be of interest to you http://tech.bentleypublishers.com/servle... Hope this helps, good luck.
这个答案有帮助吗?
I have a 530i 2002 BMW it would go in drive but it would not go in reverse and it's in my driveway help
Have you tried getting your linkage checked, and try out some transmission Luca’s that might help a lot
过去 24 小时: 11
过去 7 天: 50
过去 30 天: 215
总计 122,209
