跳转到主内容
加入维修社区 - 创建账户
1997-2002 年产 Ford Expedition 的维修指南和支持。Expedition 是一款基于 Ford F-150 皮卡的全尺寸 SUV,与 Lincoln Navigator 车型渊源颇深。
AC/Fuse or relay
My AC does not blow cold air just hot air so I need a fuse or relay or does it need to be recharged?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Without knowing more it's impossible to tell. Is your compressor running? Is it getting voltage? Is voltage getting through low pressure switch? Could be fuse, could be refrigerant charge, could be compressor. What have you checked? One way to quickly see if it's low on refrigerant is to go to the low pressure switch, pull the plug off, and use a small bit of wire to act as a jumper and connect the 2 pins in the plug. If compressor starts running then it's low on charge. Don't leave the wire for long though.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Consuelo Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 169
