跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Speaker doesn't work and the touch screen is kinda messed up?
I replaced the screen of the ipod touch for a friend. Never done a fourth gen till now and nothing but problems. Since the screen didnt fit perfectly, somebody on here suggested i use superglue. I made sure everything worked perfectly, then super glued it. Now, the speaker wont put out any sound. I can still change the volume of it, but the sound won't come out. The headphones work fine. Also, with the top half of the digitizer, swiping (ex. left to right) works fine, however, if i tap (ex. to open an app) it wont work. I am losing my mind with this!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Hopefully you didn't use too much Super Glue. That was stupid, but if you didn't use too much the damage shouldn't be too bad.
If you didn't use a lot, it's likely you can remove the old screen with little to no effort. However, it WILL get cracked during removal; there's no way around this. If you used a lot you're likely to inflict a fair amount of damage on the iPod and may damage other components removing the LCD assembly.
I'd honestly recommend just replacing the LCD shield in your iPod; removing the glue isn't going to be easy and you'll spend more time removing it then you will replacing the shield.
Once you remove the display, replace the midframe. Cleaning the glue from this part is not practical, since a used replacement that works is often cheap to purchase. A parts iPod will suffice for this if you need to go that route. As long as you can test the home button and see it works, you do not need to be picky about anything else. This is the part you now need: iPod touch (4th Gen) Midframe
After removing the midframe and LCD, check the components and flex cables inside for damage. If you see any and it's serious, I'd just replace the iPod for her and never do something so dumb ever again (if it's your fault).
Here's the parts you need:
iPod touch (4th Gen) Screen图片
产品
$29.99
iPod touch (4th Gen) Adhesive Strips图片
产品
$3.99
iPod touch (4th Gen) Midframe图片
产品
$9.99
这个答案有帮助吗?
得分 2
1条评论:
okay, screen was defective...but when i removed it, the stupid digitizer cable broke. i was so careful that the lcd cable stayed plugged in, but the somewhat longer digitizer cable snapped clean in half. idek anymore. but the speaker has snapped cables. luckily i didnt use much superglue...just enough to keep the screen on. adhesive wouldve probably been even stronger lol. so i'm going to order a new screen. i have another friend that does this all the time so im going to use his seller from amazon. could anybody point me in the direction of teh right adhesive strips? amazon seems to only have the generic ones for all generations...im only looking to spend a few bucks on those please
thank you everyone for your help!!
完成的
添加一条评论
NEVER use super glue. Who told you to do that? Seriously...
Sounds like you probably ripped the speaker cable. It is very easy to do on these model iPods during a screen repair. Also, it sounds like you probably have a defective screen. I would contact whoever you got the screen from and let them know you have a defective screen and see if they will send a new one
这个答案有帮助吗?
得分 1
2条评论:
+ good answer, I just edited the profanity ;-) No name calling amongst professionals ;-)
完成的
yes you are right i did rip the speaker cable....both actually :/ i wish i knew who told me to use superglue so i could go give them a piece of my mind...but unfortunately, idr who he was
完成的
添加一条评论
添加你的答案
Matthew Goldstein 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 2,489
