Upgrade a Toshiba Satellite C650D With a C855D Motherboard
I have a Toshiba Satellite C855D Motherboard and a person's needs his replace but his model is Toshiba Satellite C650D are these interchangeable with each other?
Thank you
@tj8799 this will only work if the physical layout of the motherboards are the same. Connectors and mounting points will have to be identical. Then you will need to check that the individual connectors are "wired" the same to ensure compatibility. I do not have the board views for these motherboards but I do have the schematics. Use those to check compatibility for the architecture of your boards. Toshiba Satellite C650DToshiba Satellite C850D C855D
这个答案有帮助吗?
Thank you will look at a c650D and image it next to a c855D and see if they look the same
Thank you again
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 36
