跳转到主内容
加入维修社区 - 创建账户
2012 年 12 月 13 日,经过重新设计的 2014 款 Chevrolet Silverado,连同其姊妹车型 2014 款 GMC Sierra 在密歇根州底特律的北美国际车展上首次亮相。
Power Lock Partially Functional (Driver Rear)
Whether I select the lock/unlock button from my key fob OR the button on the vehicle door, my rear door on the driver side only responds 50% of the time. While this is not a major issue, it's been happening for about a year, and it's starting to drive me crazy. I try to avoid going to the dealership whenever possible.
I'm assuming this is probably an electrical issue or shortage, but I'm not exactly sure of where to begin.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Ben,
I ran into a similar issue with my son's 2003 Cadillac Deville. As it turns out, the problem was in the set of wires that run between the door frame and the door itself, so that's the place I'd suggest you start. Those wires get flexed every time the door is opened and closed, and as you can see from the harness on my son's car, eventually they give up.
Yours aren't likely to be this bad, but you see what can eventually happen.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 213
