跳转到主内容
加入维修社区 - 创建账户
针对 2016 年初发布的 2015 款 Retina MacBook 更新版本的维修信息和指南。型号 A1534 / EMC 2991
Boot sequence issues and full blast fan while running
Good day, I have a 2016 MBP, battery is dead and i need to be plugged in to use it.
The issue is, i need to press the power button then plug it in to make the MBP start. Then the fan is in full blast while im using it.
Just upgraded to Sonoma via Opencore, works great.
My Main question is; what is the issue when starting the laptop. is there a hardware problem?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Given the systems age I'm suspecting the battery has failed, install this Gem of an App CoconutBattery it will allow you to see mot]re clearly the batteries health. Post a snapshot of the Apps main window here so we can see as well.
这个答案有帮助吗?
得分 0
2条评论:
Hi @Dan, Yes i think the bat is dead. WIll changing the battery help in booting process issue? and Fan on full blast?
完成的
@jujoe - If the systems sensors are telling SMC there is a problem, the SMC logic will lower the CPU's clocking as well as pump up the fans RPM as it's going into CPU Safe Mode. I suspect that is what you are seeing which is likely the Battery, but without proof of seeing the CoconutBattery screen shot I can't tell you it's the battery alone.
完成的
添加一条评论
添加你的答案
jujoe1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 175
