跳转到主内容
加入维修社区 - 创建账户
Power Mac G5 是苹果公司于 2003 年首次生产的台式电脑。本指南将介绍 2004 年款 Apple Power Mac G5(型号 A1047,EMC 2061)的维修流程。 它于 2006 年停产,当时正值苹果从 PowerPC 架构转向 Intel 架构(首先面向开发者,随后面向消费者)。
Help Identifying a Part from a G5 PowerMac
I'm currently reassembling a 2005 G5 2.0 GHz DP, M9747LL/A.
I have the following part but I can't remember where it came from, and I've not documented it in my photos I took during disassembly.
Can anyone help identify it?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What did you do? That might offer a hint where to look.
由完成的
I did a complete teardown as it was the most filthiest computer I've ever come across.
It was likely removed after the motherboard came out. Maybe somewhere around the HDD holders.
由完成的
添加一条评论
1个答案
已选择的解决方案
It's been quite awhile since I've worked on these older systems I keep thinking it's a logic board stand off holding the board off of the side panel (bottom side of logic board). Just behind the PCI slots you should see some holes where the pins and latch tab pass through to secure it.
这个答案有帮助吗?
得分 0
2条评论:
I've added two more photos, do you mean in that area?
I realise it's a bit vague, and it is my own fault for not paying enough attention when taking it apart. But I do appreciate everyone's input on this.
由完成的
Found it, it covers a cable on the lower left of the board near the RAM slots.
由完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 209
