跳转到主内容
加入维修社区 - 创建账户
2002 款 5 门版 Explorer 及其同类车型 Mercury Mountaineer 进行了彻底的重新设计,外观变得与老大哥 Ford Expedition 颇为相似。
Turn signal stops blinking.
When I turn on my turn signal, sometimes it doesn't blink at all. Other times it blinks a few times and stops. The control lever was broken when I got the vehicle and I thought that was the cause but replacing the lever did not fix the blink issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Here are the next troubleshooting steps I recommend
  • Replacing the flasher relay is cheap, easy, and likely the solution to your problem VIDEO GUIDE
  • Checking the signal lamp Frame grounding point
    • There should be a wire that attaches straight to the frame from the headlight assembly. Remove it and sand underneath to remove any rust or corrosion, and replace it.
    • Here are the signal lamps' electrical schematics
These are the easy things to check. If this doesn't get you there, I'd recommend consulting a professional auto mechanic.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan S. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 148
