跳转到主内容
加入维修社区 - 创建账户
Malibu 在 2008 年第七代车型中进行了重新设计。 这一代 Malibu 拥有多种配置级别:基础版 (仅 2008 年) (1SB)、LS 1LS (或 2011 年和 2012 年的车队车型为 1FL)、LT 1LT (或 2011 年和 2012 年的车队车型为 2FL)、混合动力版 (仅 2008 年和 2009 年) 以及 LTZ 1LZ。只有顶配的 LTZ 配置包配备了带红色 LED 灯的透明刹车灯罩,其余配置包均保留了带有传统刹车灯泡的红色灯罩。
What wrong with my car
the engine shakes and doesnt go past 30 miles per hour
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Shauna,
Since 1996 all US cars are required by law to have an On-Board Diagnostics (OBD-II) port and a standard set of protocols for communication. The OBD-II port allows you to hook up a scanner and read out the Diagnostic Trouble Codes (DTCs) generated by the engine computer. Any problem bad enough to cause your car to run like it is should almost certainly cause one or more trouble codes to be set.
So the first step for you is to find out if there are any trouble codes present. If there are, they will give you and us an idea of where to look for the problem. Here in the US, most auto parts stores will hook up their scan tool to your car for free and give you a list of any codes they find. Alternatively, you can buy an inexpensive OBD-II scanner at the auto parts store or online; some of them are pretty cheap. There are also Bluetooth dongles that plug into the port and link to your phone; you can download free apps to read out the DTCs; I personally use one called Torque. Those dongles can be had for around $5 or even cheaper online.
Once you have that list (or find there aren't any codes), come back and edit your post to add that information. The codes will consist of a letter followed by four numbers, such as P0103 for example.
Once we know what kind of codes you have, we'll be better equipped to try and point you in the direction of a fix.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shauna Rae 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 211
