跳转到主内容
加入维修社区 - 创建账户
HP ProBook 440 G7 笔记本电脑的维修与拆解信息。这款 14 英寸商务笔记本电脑于 2020 年生产。
Keypad is no longer working
Hi All,
I’m reaching out to kindly ask for your help regarding my 5-year-old HP ProBook laptop. I’ve recently encountered an issue where the keyboard suddenly stopped working, and I’m unsure what caused it. As much as possible, I’d like to avoid any hardware replacement, so I was wondering if there are any troubleshooting steps or possible fixes I could try first.
Any guidance, suggestions, or support you can provide would be truly appreciated. Thank you in advance for your time and assistance!
Update (07/24/25)
Hi Jayeff,
Thanks you for checking my inquiry. I have checked it and as per image below it is working properly.
As for the concern if it’s gotten wet, when I am cleaning the keyboard I usually used a wet wipes to remove the dirt.
What do you think the best thing to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @jobertfernando
Has the laptop been dropped or the keyboard gotten wet at all?
Have you tried connecting a USB keyboard to the laptop and checked if that worked OK?
Check the status of the keyboard in Device Manager to see if Windows shows that it is installed OK.
Go to Device Manager → Keyboards → > → right click on HID keyboard device entry → Properties → General tab and check if it shows "This device is working properly" in the Device status box.
To get to Device Manager in Win10/Win11 press the Win key + x key (both together) and click on the Device Manager link in the menu box.
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi @jobertfernando
Wet wipes aren't the best thing to use to clean keyboards simply because they're too wet.
Most probably over time, liquid from the wipes has gone down between the keys and affected the circuit board underneath that the keys are attached to.
Any liquid is the enemy of electronic circuits as it causes corrosion to occur and it also creates unwanted electrical circuits which may damage the components.
The best option is to get some Isopropyl Alcohol 99%+ (available from electronics parts stores) and spray a bit into a lint free cloth just enough to lightly dampen it i.e. not dripping and gently wipe the keys clean. The beauty of using it is that not only kills germs and cleans, it also evaporates quickly and leaves no conductive residues afterwards, thereby greatly reducing the chances of causing liquid damage
Fixing keyboards is not easy as mostly you can create more problems than what was there before. Most repairers simply replace the keyboard or in this case the keyboard/top cover assembly.
If you decide to replace the keyboard/top cover assembly, here's the maintenance and service guide for the laptop that will help.
Go to p.74 (82 of 110 pdf) to view the procedure to remove the keyboard/top cover assembly.
As you will see, you will have to nearly completely disassemble the laptop to do this. Also the keyboard is part of the top cover assembly and usually not a separate component.
You can find separate compatible keyboards but this means that you would have to either cut or melt the nylon or metal rivets that attach the keyboard to the top cover and if you do, then work out how to reattach the new keyboard in its place.
Also on p.74 in the guide you will find the HP part numbers for the various types of keyboard/top covers that are compatible with the model. The keyboards are also country specific, so you have to work out what type of keyboard/top cover you want out of the 3 choices available and then find the country code suffix to add to the part number you found and then use that number to find suppliers that suit you best e.g. a top cover with keyboard, no backlight for Spain is L65225-071, whereas the same keyboard type for the USA is L65225-001. Usually the part number is also found on the underside of the top cover/keyboard assembly if you want to verify which one you have now.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jobert Fernando 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 72
总计 507
