跳转到主内容
加入维修社区 - 创建账户
HP Envy x360 是该公司自 2014 年起生产的笔记本电脑系列。它们配备了触摸屏和可全方位旋转的显示屏。
Can we change Ram.
HP envy x360
Update (07/22/25)
Here is the image
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @amarjitsah
Wat is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
完成的
HP envy x360 convertible
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @amarjitsah
Your laptop is a HP Envy 13-ag0035AU
Unfortunately, the memory cannot be upgraded in the laptop.
There is 8GB of onboard memory on the motherboard which is non removable i.e. soldered onto the board and there's no extra memory slot on the board to insert any more.
You're limited to what you already have.
Here's the maintenance and service guide, taken from this support page for your exact model¹. Go to p.32 (40 of 79 pdf) to view the procedure to remove the memory shield which exposes the onboard memory, if you wish to verify.
¹ Note that the model number (HP ENVY x360 - 13-ag0035au), serial number (8CG92482W6) and product number (5FP71PA) for the laptop shown in the support page is exactly what is shown in the image that you posted.
这个答案有帮助吗?
得分 2
4条评论:
How to improve it's overall performance?
完成的
@amarjitsah
There's nothing that you can do to the hardware that will improve performance.
There's already an SSD installed for storage (they are faster than a HDD), you can't increase the memory, and you can't replace the CPU.
Make sure that the Windows OS and the hardware drivers (check in Device Manager) are up to date and that there are no viruses or malware installed which could slow things down
完成的
But in cmd prompt it shows that I can upgrade it upto 32 gb ram
完成的
@amarjitsah
Open up the laptop and you will find that there's no way to do this as you cannot remove the old ram and there's no empty ram slots to install any more.
完成的
添加一条评论
添加你的答案
Amarjit Sah 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 105
总计 1,937
