跳转到主内容
How to remove a stuck screw
While attempting to change my LCD screen, when I got to the part of removing the left screw that is half threaded it just turns but never unscrews. Can anyone help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I use a pair of needle-nose Tweezerman tweezers to grab right behind the head of the screw and pull outward, while simultaneously unscrewing it with my other hand.
Also, if the screw is loose but just not coming out at all, sometimes tilting the laptop so that the laptop is facing the ground can cause it to fall out, or at least come out to the point where you can pull it out with tweezers.
这个答案有帮助吗?
得分 3
1条评论:
OK here's the up vote (not) from the other screw question. Looking at your icon, it's obvious you have more loose screws than I do ;-)
完成的
添加一条评论
If you can get it up a little, snap the head off with some wire cutters. Later you can grab it with some needle nosed pliers and try to get it out. These things have so many screws that usually not getting one in is no problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,139
