跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Odd trackpad button clicking noise
This morning, my 2 year old MacBook's trackpad button started making these clicking noises every time I pressed on it. But it also depends on where I press down. The noise would be there on the right side sometime, and sometimes on the left. What could be wrong? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
What exactly do these clicking noises sound like? How do they differ from that of a normal click? Is the actual upper case surrounding it broken in any way?
完成的
Normally, the sound it would make would this dull, quiet, *thuck*. Now it's this metallic, loud, *CLICK*. Sounds like a spring inside is in the way or something
完成的
添加一条评论
4个答案
已选择的解决方案
Something very small could be stuck under your click pad. Try to insert the corner of a paper sheet under the click pad and slide it to remove the "intruder" out. Or buy the newer MacBook Pro, there's no click pad anymore in the trackpad assy LOL...
这个答案有帮助吗?
得分 7
3条评论:
Placed a piece of paper, moved it gently and found some slight resistance. Move the paper in and out and out popped a piece of dirt or food particle? Either way, after years of an annoying high click sound its back to normal!
Thanks!
完成的
This helped quiet the noise in the left click a lot -- thanks! Wonder if there's something that would complete the process? It's still a little noisier than the less-used right click.
完成的
Thank You So Much
完成的
添加一条评论
最有帮助的答案
I just had the same thing happened and I held down the button and blew really hard into the area. Good as new! A trusty old Nintendo trick! :)
这个答案有帮助吗?
得分 10
5条评论:
this is amazing!!!!!!!!
完成的
Worked right away!
完成的
omg this worked!!!!!!!
完成的
this actually worked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
完成的
wtffffff, just workeddddd!!!!!
完成的
添加一条评论
Try tilting the Book and see if you can get the obstacle into a corner, tapping the button lightly. Then use a business card to push it out.
这个答案有帮助吗?
得分 2
添加一条评论
it just worked for my dell, the problem is little particle of dirt or food , stick a small piece of paper in the edge around the touchpad thing and go all the way around then blow all the way around really hard and it should fix it. i promise, may not seem as if thats the problem but it is. it did fix mine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
10858083 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 52
总计 24,300
