跳转到主内容
加入维修社区 - 创建账户
第七代 Apple iPad (Wi-Fi 版) 的维修指南、拆解及故障排除信息,提供 32 GB 或 128 GB 存储容量。于 2019 年 9 月发布。型号为 A2197。
TG0B Kernel Panic
Got the same issue
I replaced the battery but still getting the TG0B error. The battery level is fluctuating as well. I checked the capacitor C8923 and I got diode resistanc f .883 not sure if this is too high. FL8900 is good as well. What Iam not sure is the Q8900 which for BATT_SWI_FL.
The C8922 which is for BATT_NTC is ok as well it go straight to PMU chip. I tried to jump a wire from the battery terminal directly to batt_ntc n C8922 in case the connection going to the battery is loose but still getting TG0B ... This issue is a pain.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Migrated from this question.
由完成的 分享
添加一条评论
1个答案
Did you screw in the battery all the way? I had this error as well on my iPad 7 after a logic board swap. It kept having a kernel panic and reboot every 1-3 minutes or so, and the battery wouldn't charge anywhere past 19%. Turns out I forgot to screw in the battery which was causing the connection between the logic board and the battery to be weak. Try screwing the battery if you need to, if not, then not all pins might be making a connection which would require some soldering.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jerson Macapanas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 41
总计 254
