跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A53 5G 是三星于 2021 年 3 月 17 日发布的一款中端手机。
Microphone No Longer Working
As the title says, my microphone is no longer working. I have spoken with a repair shop about it, and it is not the physical microphone. It is the hardware/board, and I was informed I was better off getting a new phone than trying to fix this issue. The only issue is I don't have the money at the moment for a new phone. Has anyone else had this issue / knows what to do before I go try and finance a new phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Your phone has at least two microphones; one at the bottom of the phone that you use when on a phone call, and another at the top that's used for recording videos, switching to speakerphone, etc. If neither one works, that would tend to support the diagnosis of the repair shop that it could be something like a failed audio chip or something along those lines. However, if one or the other does function, I would lean toward it most likely being the microphone itself, although it could theoretically be a connector issue, but frankly those are rare - but then again, so is a failed audio chip.
Let us know if it's just one or both of the microphones that's not working and we'll see if we can figure out something that might help. Make or receive a phone call and try switching to speakerphone and see if the person on the other end of the line can hear you in either case.
这个答案有帮助吗?
得分 2
1条评论:
Hi @nobeliumsense
Just to add to the above, try connecting a set of headphones with a microphone attachment to the phone and check if you can be heard when on a call.
If you can then this proves the TX (transmission) circuit in the phone is working.
由完成的
添加一条评论
Dial #0#, a test menu should appear. Click on loopback. You should see 2 or 3 microphones. Click on number 1 and speak into the lower microphone, you should hear it come out of your ear speaker. Do the same with 2 which is on the top. if one doesn’t work then the audio chip should be ok and the microphone needs replaced. If there is no sound from either microphone then your board has a fault.
这个答案有帮助吗?
得分 1
2条评论:
*#0*# star hash zero star hash
由完成的
#0# doesn't work on my A53 5G. I get an error message; but *#0*# does. However, to test the mic(s) I have to access the 'Loopback Test' in the bottom right corner.
My problem is that the microphones (both of them) only work if I flex the entire phone. If I hold the top right corner (looking at the phone), and bend it forcefully back, at the same time that I also bend the bottom left corner--pushing the back of the phone in the middle--I can get both to function until I let go.
So, this is obviously a hardware issue. But where would I look to find common circuitry between the two, since they are separated as far as they can be and be on the same phone?
由完成的
添加一条评论
添加你的答案
nobeliumsense 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 62
总计 918
