跳转到主内容
加入维修社区 - 创建账户
iPhone 12 mini 于 2020 年 10 月 13 日发布,是苹果 iPhone 12 的较小版本。它配备 5.4 英寸 OLED 显示屏、A14 Bionic 处理器以及后置双摄像头。
Sim tray inserted wrong way
I have inserted my a sim tray from different iphone and inserted it in this one, that too the opposite way/the other way around. Now the tray is half way stuck and it’s not coming out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If it's jammed, then pulling it out will either break the tray, leaving half still stuck inside, or damage the sim, or warp the sim reader
Solution: get a spare sim reader part, and then pull out the old one, with pliers if you need to. If it breaks or scratches, you get the spare reader
这个答案有帮助吗?
得分 0
添加一条评论
Sounds like you have damaged the sim reader by trying to pull it out. The tray has probably caught up in the sim contacts inside the reader effectively trapping it. Try this.
Cut a fine piece of plastic just slightly narrower than the sim card. Slide it gently into the sim slot above the tray that is stuck inside. If the plastic jams you may have to push the tray slightly so it moves away from the contacts. If the plastic goes all the way in try pulling out the tray.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Awez Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 38
总计 394
