跳转到主内容
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
How do you identify tactile switch specs on the BDM-010 PCB?
Does anyone know how to identify the tactile switch on the BDM-010 Playstation 5 Dual Sense Game controller PCB? Does this apply on BDM-010/020/030 as well?
I had made the mistake of ordering a tactile switch that didn't exactly match the OEM part on the PCB. It was larger.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi! Can you share some pictures with us regarding the tactile switches?
Thanks!
完成的
Pictures have now been added. Thanks for pointing that out.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Will!
Thanks for the pictures! It’s easier to have the exact right switch for the dualsense mothetboard you need! So far I know, the tactile switches are the same for all the dualsense motherboards. BUT, they are hard to find.
The most easy way is to buy or get yourself a broken motherboard and get the switch from there.
Another option is to try a smaller switch, but the problem is that they do vary in size.
这个答案有帮助吗?
得分 2
4条评论:
I've been doing some researching and online shopping and found some that are similar but not identical. I'm fine with a new one that is equivalent to the specs of the oem so I can solder it on. I'm unsure on how to desolder such a delicate part from a junk motherboard anyway. I am comfortable with soldering. If this helps?
Do you know if the original part is 3.7 mm x 3.7 mm? Is it anywhere near these attribute values:
Body size (L × W) 3.7 mm × 3.7 mm
Height 0.35 mm (ultra low-profile)
Pin pitch 3.5 mm (lead-to-lead spacing)
Actuation force 1.57 N (160 gf)
完成的
Yes, you need to de-solder it in the corners most of the time. It's hard to desolder it, but you will get there. A lot of patience is needed too.
Not sure what the size is of the original switch, I'm sorry. Best thing to do is to measure it (if possible). But it will be hard as the new universals one, can differ in size by just milimeters..
完成的
@dan0 Thank you for your help!
完成的
My pleasure! Good luck with the repair!
完成的
添加一条评论
添加你的答案
Will Whitelow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 148
