跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad Gaming 3 15IMH05 是一款定位入门级的游戏笔记本电脑,旨在提供可靠的游戏体验。本页面提供该笔记本电脑 81Y4 型号的维修指南,并解答部分故障排除问题。
Why are some keys not working?
Some of my keys on my keyboard are not working. Keys like the T,A,Y,C and number 3 do not respond however you can push it and veel it go down slightly just like pressing any op the other keys. What should or can I do to repair it? What could be the cause?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi @annikaarke96654
Has the keyboard gotten wet?
If it has gotten wet or even if it hasn't then it could be a faulty keyboard matrix, but in trying to fix a keyboard you can create more problems than you originally had so it is easier to simply replace the keyboard.
To do this you would have to nearly completely disassemble the laptop.
Here's the hardware maintenance manual for the laptop.
Go to p.43 (49 of 60pdf) to view the procedure to remove the Remove the upper case (with keyboard and touchpad).
Lenovo doesn't supply the keyboard as a separate part. It comes as a complete module with the upper case assembly. You will have to remove the touchpad from your laptop and insert it the new upper case assembly though as it isn't part of the module. You could try sourcing a compatible keyboard only, but this would involve either cutting off the nylon plugs that fix the keyboard to the assembly or drilling out the metal rivets that hold it on, (not sure which method is used in your model). Then you would have to somehow glue the new keyboard back in place.
Also there are 64 different keyboard upper case assemblies available for the laptop. They are country i.e. language, colour and backlit (Y/N) specific, as well. The easiest way to know which is the uppercase assembly for your particular model is to look for the part number located on the underside of the uppercase assembly e.g. 5CB0Z20927 (USA) , 5CB0Y99514 (GER) etc, and search online using the part number to find suppliers.
If it has gotten wet besides having to so the above, you would also have to check if the motherboard is OK and hasn't also been affected e.g. corrosion or other liquid damage
这个答案有帮助吗?
得分 1
添加一条评论
Well the min reason for this are:
  • Water or Liquid Damage
  • Keyboard Ribbon Cable is Loose or Damaged
  • Driver or Firmware Issue
  • Internal Keyboard Circuit Damage
So Check you keyboard for all of the issue mention above, And also try to use a another keyboard and check does the issue exist, If yes the outdated or corrupted can be the main reason for this so updated your keyboard driver to it's latest version.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Annika Arkesteijn 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 45
总计 517
