跳转到主内容
加入维修社区 - 创建账户
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
PS5 Continuous startup loop?
When I start up my console. It will start up and go into the gold and blue animation at the beginning of start-up. It goes until the gold and blue intertwine and will freeze.
Then it will boot back to the startup and do this over and over going to the same place each time and freeze and then reboot.
Has anybody else experienced this, and if you did what did you do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi!
Hmm, sound like the software or firmware is corrupted.
First, can you enter the safe mode menu? I would completely erase the PS5 and start over again.
If there is a option to update the system, please do this as well.
If the issue persist after updating and after a complete format, then you might want to check the SSD.. This won't be easy as it is soldered on the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marty Robinson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 55
总计 463
