跳转到主内容
加入维修社区 - 创建账户
Drive shaft is stuck
I cannot get the tiller tine drive shaft loose. All the videos I've found show pristine Mantises, and the shaft is easily undone. I'm working on its left-hand side (as I face it with the handlebars in my hands), and use the appropriate 'leftie-loosie' thing (AKA: Counter-clockwise) as shone in all of the videos. But the darn thing just will not unwind. Any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Can you remove the tines? Tip the tiller forward so that it rests on the tine guard and fuel tank, and apply penetrating oil such as WD 40 specialist. Leave for a couple of hours, then use a pipe wrench to remove the shaft. If it still resists, gently tap the wrench with a hammer to break the seal, then continue turning it out. My neighbour did this for me. Hope it helps :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathy Swan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 125
