跳转到主内容
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
My Nintendo keeps getting stuck
My nitendo keeps getting stuck when ever i touch it or put it somewhere, the screen shows white block on it, and sometimes it shows a blue screen, i even replaced the thermal paste too...
Update (06/24/25)
Here are the videos
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi! Could be a lot of things. Can you provide us with photos or a video? Thanks!
完成的
[video|7053]
[image|3689039]
[video|7052]
Here are the videos
完成的
添加一条评论
2个答案
已选择的解决方案
Hi!
Thanks for thr video’s!
Alright, this seems a touchscreen issue at first. But as it is crashing, it could also be the motherboard. Now the blue screen is worrying me… it is most of the time CPU relate tho. Does it comes out of nowhere?
Anyway, I would say it’s the motherboard/CPU which is starting to die…
I would replace the motherboard. But this will be expensive.
If you need a guide, please let me know!
这个答案有帮助吗?
得分 3
3条评论:
Thank you,
Like you said above it is not out of anywhere, it only happens when i flick it ( like in the video)
完成的
One more thing, when ever it get stuck it make a weird noiese like a hair cutting machine
完成的
Yeah, the Switch is completely crashing... Probably motherboard related I'm afraid...
完成的
添加一条评论
That looks like a pretty classic Switch Lite Blue Screen to me. Which is unfortunate, because that could be a few things, most of which are difficult to fix and are related to the motherboard. Often its a slight bend, or a drop which breaks connections under the APU or RAM, or could be some issue with their circuits.
The easiest thing to do here would be to replace the board unless you have any sort of microsoldering experience.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Umer Abubakar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 123
