跳转到主内容
加入维修社区 - 创建账户
第一代 Cadillac CTS 在 2003 至 2005 车型年期间推出,首次采用了该品牌基于后轮驱动 Sigma 平台打造的“艺术与科学”(Art & Science) 设计语言。
No accelerator/throttle response
Hello, cadillac people. This is my first cadillac experience and I need some help. I was are certified back in the 80's&90's but I just bought a 2005 cts with a accelerator/throttle issues.there is no throttle response! It cranks up and idles fine, it'll run all day long. I can put it in gear and idle all over the parking lot but no throttle press on the accelerator and nothing happens stays at idle I've replaced the accelerator pedal position sensor, twice, the throttle body assembly, twice, and the ecm, once. And it's still the same. I've checked the 5.v reference wires I have 4.9 v.
The signal wires fluctuates smoothly when pressing on pedal. I keep getting the same 2 codes 2122, and 2127 accelerator pedal position sensor circuit 1 and 2 low voltage.
I am lost as to what the problem is! Also when you turn the ignition on I can hear the throttle actuator motor running, moving the throttle! I tried several relearn procedures, to no avail! Can someone tell me what I'm missing, please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What engine do you have? And what transmission?
由完成的
添加一条评论
1个答案
this is mean no fuel reach to the injections, check the fuel pump pressure, if it can supply the engine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony Caldwell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 346
